Power Supply recomendations
I am pretty sure someone asked a similar question recently,however........can anyone recomend a 240ac- 12volt dc power supply to run a charger and tyre truer off (not at the same time before someone asks!)
The local Jaycar sold me a 4amp switched ac unit and it was ok up to 1amp charge only.
Any thoughts/recomendations much appreciated.
gt
gt
Squizzytaylor,
I'd take the power supply back to Jaycar and get STOCK-CODE: MP3112.
13.8v 18Amp switchable powersupply.
Registered User
Jaycar (& Metro Hobbies) sell a 15 amp power supply that can run your charger and tyre truer at the same time for around $170.00 .
If you sell your tire truer and use use rubber tyres...problem solved !
(...please forgive me... Victorian humour here..... )
Thanx guys!
gt
gt
Hi, it was me that asked about the other power supply question. I recently tried out a computer power supply and it was fine in terms of voltage and amps. However, you have to have a decent one to do this though (I used the AOpen 300W psu from my dually workstation) . I am going to buy my stuff overseas now so I will be getting a proper power supply from integy. The 14A SHE is a good buy in hong kong for about $120 versus paying $80-$100 for a good computer power supply which has to be modified.
good buy in hong kong for about $120 versus paying $80-$100 for a good computer power supply which has to be modified. [/B][/QUOTE]
I payed $2 for my power computer power supply at the dump.
It do not compear to the ONE i just brought ready to go.
Save the extra dollars its worth it.
120 dollars
u can pick up power supplies for 40-50 bucks
also your not surposed to use them for that, it can cause troubles i heard someone say
if ya want one of the best, this is what i recommend ,
variable output voltage from 3 to 15VDC
switch mode power supply will deliver up to 40 amps
avaiable from Jaycar electronics
Quote Sausage link
"120 dollars
also your not surposed to use them for that, it can cause troubles i heard someone say"
I totally agree with the trouble you get with the 40-50 dollar computer PSU. The same problems also occur in computers. They usually only pump out 11v and have huge spikes in amps. I was just trying to show that if you do have a decent server/workstation computer power supply and are willing to sacrifice it, it will work just as well; and yes those kind of power supplies do cost $100+ and are not the type you often see in many computers. I just suggested these kind of power supplies as an alternative because they work and are within a competitive price range compared to a proper one. Also if you know what you are doing, you can get used ones very cheaply.
"120 dollars
ahh ok
i thought u just meant a standard 300 watt pc powersupply
hey there
i picked up a whole bunch of computer power supplies for $5 each at a local second hand computer store, just make sure the ratings are 8 amps or more at 12v and you are all set, mine were all rated at 12 amps or higher and work great.
Hawker, can you check the numbers with a voltmeter/ampmeter while the power supply is powering the charger? I think 8 amps max for the 12v rail is a little too low. Most old power supplies have a 15-25A max and they rarely produce a constantly clean output. thats why server grade psu's and motherboards have such huge capacitors. However, if you have got it working good, I am very jealous becauase it cost you $5. If so, what brand and model is it?
i'll try to get a reading for you next race meet, but it seems to be clean flow of power, i get better run times charging from the power supply than from a battery, the power supply model number is:
Brand: IPEX
Model number: ST-230WHF
that has a 12amp output
you need to get the old style ones with the big push button switch on it because the newer ones have there on/off function controlled by the motherboard.
Brand: IPEX
You can use an ATX, WATX etc type PSU. All you have to do is short or wire a switch between pins 15 and 16 on the motherboard header......i think. From memory, they should be the middle two pins.
Did you mean a 12v output? It should be something like 12V 20A?
Also if you want more voltage, you have the option to wire up the +12, -12, +5, -5, +3.3 and -3.3 lines in any way you want so you can get a bit more or less power. I.E using the +12 and -5 will give you 7v
