Go Back   R/C Tech Forums > International Forums > Australian Racing
Old 05-09-2006, 12:14 AM   #1
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Default "BLING""BLING" Hyper 8
Welcome the newest competitor to hit the racing circuit: The Hyper 8 Pro! The new Hyper 8, by HoBao, has been redeveloped from the ground up, incorporating the most successful aspects of the world reknowned classic Hyper 7, along with the newest engineering and manufacturing techniques, to bring you the most technologically advanced and economically modest Gas/Nitro RC Race Buggy in the world.
Everything has been lightened and strengthened, while the focus remains on professional performance and ease of maintenance. Trick polished chrome and high quality aluminum give the Hyper 8 the bling to stand out from the crowd. Beautiful form and aggressive function at an affordable price. Pro drivers like Jeremy Kortz and World Champ Greg Dagani have made the switch to the International Hyper Team to drive the new Hyper 8 by HoBao. But why should they enjoy all the success? Get your own Hyper 8 today and become part of the winning team!
Center of gravity and roll center lower than the previous model. Large air filter profiled for improved air induction. New suspension geometry, Independant Suspension, C-Hub steering. Variable ackerman angle setup center tie-bar. Lightweight curved suspension arms to maintain strength. Steering ball ends shaped for max steering without lock without fouling. Chassis is 20g lighter than the original Hyper 7. Adjustable wheelbase. Power switch mounted down for safety. Smaller shocks with more travel. Upper arm designed with angled ball joint to prevent wheel bind. Everything has been mounted closer to the center of the chassis for championship-winning performance.
Features:
Carbon Fiber radio plate, diff plate, and steering plate.
Big Bore Oil-filled shocks with Teflon pistons.
Bushing retained suspension hinge pins.
Oil filled and sealed gear differentials.
Full ball bearing set.
Adjustable caster C-hubs.
Milled 4mm thick aluminum shock towers.
Hard anodized aluminum chassis.
Adjustable tie-rods and steering links.
Polished aluminum chassis braces.
Metallic radio box cover.
5-hole Revolver Racing Wheels and Fire Tires.
Laydown steering servo.
Dual bellcrank with servo saver.
Aluminum center dogbones.
High performance polished, tuned pipe included.
Steel spur and clutchbell.
Ultra rigid suspension arms.
Low profile racing body and sleek wing.
Front caster block has interchangeable inserts for different caster angles, does not require removal of driveshaft.
No E-clips, Inboard hinge pins in captive supports front and rear. Outboard hinge pins secured with setscrew.
Rollbars have one piece molded connectors, which are accurate and light weight.
Gearbox casing more compact and is not chassis mounted for protection, with diff mounted lower
New fuel tank does not require 90deg opening for fast filling.
Rear hubs feature interchangeable inserts to alter track width by 0.15mm each side.
New 2-piece brake mount for quick spur gear change.
AMB mount features wire runner for personal transponders.
Sealed radio box for water protection and easy access with the antenna tube held in with setscrew.
Rear upper arm features angled ball joint to allow more suspension down travel without binding on wheel.
Rear toe-in adjustable with different color hub inserts.
New suspension geometry allows more travel combined with smaller shocks for less weight.
Shocks feature 3.5mm shafts and more space behind blatter for more consistent performance.
New caster blocks. Choose from 18, 20, or 22, bottom block of C-hub changes caster.
New design fuel tank and high flow air filter as well as sealed chrome top radio box.
A smaller gear box, new suspension geometry and light weight arms allows for more travel.
On Average 200grams lighter than equivalently fitted Hyper 7 PCR PBS PRO.
"BLING""BLING" Hyper 8-ohbh8pro.jpg   "BLING""BLING" Hyper 8-c_ohbh8pro-13.jpg
dirtdustingdavo is offline   Reply With Quote
Old 05-09-2006, 12:20 AM   #2
Ive seen those buggies at Hobby Habit SA and theyre sick. Must be getting meself one!
understeer is offline   Reply With Quote
Old 06-03-2006, 03:35 AM   #3
MadRacer's Avatar
Trader Rating: 33 (100%+)
Lets hope they do better at the worlds this time. The Hyper 7 was great, hope this time they will not get dq at the worlds..
Boondal vintage Tamiya's
https://www.youtube.com/watch?v=vtmCddStNyM
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Old 06-04-2006, 01:39 PM   #4
cantona's Avatar
maybe they will keep a closer eye on their fuel system capacity...
cantona is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 06:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 05:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 08:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 09:04 PM
NEW kyosho V ONE R main chassis & top deck for sale cheap """" sheridans R/C Items: For Sale/Trade 0 10-03-2003 05:12 PM
