Losi XX4 owners please help with a few measurements.
For anyone who has a XX4 I have a favor to ask.
I need to know the length of the front and rear suspension arms measured from the centre of the inner hinge-pin hole to the centre of the outer hinge-pin hole.
I also need to know the measurement from the centre of each shock mounting position to the centre of the outer hinge-pin hole in the arm, again both for the front and rear arms.
thanks
thanks
Front Arms-Shock holes:
Outer mount-outer hinge pin :29.5mm (nominal)
Middle mount-outer hinge pin :33 mm (nominal)
Inner mount-outer hinge pin : 35.8 mm (nominal)
Rear Arms- Shock holes:
Outer mount-Outer hinge pin : 14.8mm (nominal)
Inner mount-Outer hinge pin : 19.5mm (nominal)
