Trueing Rubber Tyres
Does anybody do this, It occured to me when I ran a Mini I have.
I put a new set of treaded tyres on the car and after a couple of runs the wear patter was extreemly patchy so there was obviously high & low points on the tyre. It looked OK to the naked eye (it looked round) before the run.
If I had a camera you would see the wear, tread depth in as much as a millometer different in sections.
If the tyre is spinning arround and there are high & low points (ie the tyre is not true) it would be lifting off the road for a split second, threfore it would be loosing grip, no amount of suspension adjustment would be able to stop this lifting as the tyre rotates.
Can you true a rubber touring car tyre and how?
I have not seen anything on any of the threads about this.
I just rotate my tyres every run, so hopefully they get even wear. I have heard of sanding tyres when they are new to get rid of the centre line.
I'm fastest in mini at my local track by a lap or two.. the mini is standard (except ESC).. standard silver can, standard friction shocks, everything standard.
my secret...
bald kit mini tyres on back, and half decent kit or super grips on front.
mini's understeer, badly. with bald rears i can get the mini to 'drift' into each corner and maintain some momentum around the track.. it really is rather funny to watch, but it kills the other 'more hopped up' mini's on the track...
pretty funny stuff
the tyres in the kit dont last long, at all.. as mentioned a few packs, max...
my secret...
pretty funny stuff
If you mount the rubber tires and they are not sitting flush on the rim there is nothing you can do about it, the tire when used will attempt to wear itself true, and will eventually wear the high spot down to the canvas, even iff the rest of the tire still has plenty of tread left.
I get uneven tyre wear when I run ****** poxy Yokomo rims!They inevitably crack after a hit and develop a high spot during the race.
Sounds interesting when cornering,hearing the broken spot clicking on the upper ballcups!
The answer to your question is YES
To answer your question I would have to say yes I have found running my sorex tyres accross my eagle tyre lathe has helped to get quite a few more runs out of tyres that looked ready for the bin. Basically I am too lazy to rotate my tyres during club meets, so they often have different wear rates on each corner at the end of a raceday. Before I use them again I give each tyre a light skim on the tyre lathe to even them back out again, them with the lathe free spinning I run some WD40 soaked wet & dry fine grade sandpaper accross them to both polish and condition the tyre surface. So far this process has restored most of my tires back to race ready status, generally giving me an extra 2/3 race meets out of a set. Hope this info helps.
Cheers
Jace
Cheers
Jace
