Qld Gas Tourer State Titles and EP Super Stock Championships
Queensland Radio Circuit Car Racing Association inc. (QRCCRA) along with ORRCA Qld are pleased to announce the Gas Tourer State Titles and EP Super Stock Championships.
When: 16th to 18th May 2014
Where: England Park Raceway, Strathwyn St, Brendale
Classes are Gas Tourer as per ORRCA Qld rules and EP Super Stock as per QRCCRA SSF rules. Rules sets can be found here:
http://www.orrcaqld.org.au/rules-for...ourer-section/
http://www.orrcaqld.org.au/wp-conten...ersion-1.0.pdf
Tyres for Super Stock will be open foam or rubber with no traction additives allowed.
Entry form below.
Entry form below.
Due to a minor miscommunication, I posted the wrong rule set for Super Stock. We will be using the ORRCA rules and tyres will be open rubber or foam, with no traction additives allowed on either.
I have amended the entry form and edited my original post to reflect these changes.
Also note that for this event motors do not have to be on the ROAR or BRCA lists, however they will still be subject to inductance tests during the event.
Lets start creating some hype people!
1 week to go!
Maybe we could get a nomination list up if someone has time?
I emailed my form through could I get a confirmation that its been received please that'd be great.
Cheers Dave L
1 week to go!
Cheers Dave L
I'll get up a list later on today, we are going to be flexible on the closing date for nominations. So there is still time to get your nominations in.
While we are going to be strict on ROAR approvals for experienced drivers in SSF, for those Novices that have things like 10.5 Trackstar motors we will leave it up to the club to decide.
So if you are new to this kind of regulated competition please don't be afraid to give it ago.
Look at Dave, he's still a Novice and he's going to have a go. :-)
Graham
Good idea Dave,
Graham
Graham
Drivers list
Any mistakes please let me know,
Gas Tourer
Nathan Knibb
Andrew Crowley
Conner Shapland
Ray Griffiths
Les Ralston
Kerry Crowley
David Langham
Marty Hall
Andrew Crowley
SSF 10.5
Peter Beckett
Micheal Redmond
David Langham
Sean Vallely
Jason Vallely
As commented on above, the club can use its discretion with respect to ROAR Compliances in SSF. The Stated motor is a good example of something that is in wide use and is not any more competitive then anything else.
Graham
Gas Tourer
Nathan Knibb
Andrew Crowley
Conner Shapland
Ray Griffiths
Les Ralston
Kerry Crowley
David Langham
Marty Hall
Andrew Crowley
SSF 10.5
Peter Beckett
Micheal Redmond
David Langham
Sean Vallely
Jason Vallely
Graham
Arh wow these numbers make me want to cry! Whats going on!?
Im only seeing some Brendale racers in that list, what about the other 25 regulars we get every Friday?
And more importantly the other clubs!?
Ive seen better 'Association' in bikie clubs!
As Graham said Ive just started and Im 'giving it a go' ;-)
But as much as I think Terry Langham is a top bloke I
still think my last names better hehe
Cheers David 'Langan'
So just to clarify... it up to the CLUB's discretion as to whether they choose to run the ORRCA rules?
The club has an entry form which has been posted, and rules will
Be run as per the entry form
The club has ask for some latitude on some motor specs and orrca Qld has left it up to the club
Induction test will be performed on motors randomly
Hope this helps
Thanks for the question Woda
Thankyou for your answer.
Considering the confusion some people may have had over the rules it would only seem reasonable that vice presidente graham1234 should edit his above statements.
Just another quick question and I don't mean to be a rule buster, but I'm pretty sure the rule states for maximum width on wheels/tyres is 27mm wide by ORRCA but what will happen if your running foam rear tyres which are 30mm wide, plus I think the cars overall width will be over the 190mm as well with foams. Will this be over looked for this certain event I just want to clarify this before the shit hits the fan.
Thanks Michael
Thanks Michael
Thanks Michael
Thanks Michael
Last night I walked through the pits and put a ruler on as many different cars as I could and most were under 190mm wide by 2-3mm. The few that were over or right on the limit were Associateds and Hobbyking cars. The AE cars were only over by 1-2mm at most and some of them were actually 1-2mm under the limit. The one Hobbyking car that I measured was about 197mm.
It is also worth noting that for quite a while, Tim Weier has been running his Tamiya with cut down foams on the rear, instead of spacing them out. Tim is always at the pointy end of the field and often comments that he still has too much rear grip to get the car to rotate fast enough, despite the narrower foams and 0º rear toe.
