~ 2012 ORRCA QLD EP10 OFFROAD STATE TITLES ~
#47
Check out the 17.5T motor rules for the titles it says motors must read above 60mH assembled,
sweet as so since mH is milli and not micro (uH) I can run a 10.5T in a 17.5T can and it will read under 60mH.
lol, lucky im a intense rule reading nerd to pick up these typo's
Also a LRP X12 17.5T straight from the box reads 58uH So will it be allowed??
I'm sure there will be a tolerance of a few % so I'm sure your 58uH will be fine
and I'm sure if someone tried to run a 10.5 rotor in a 17.5 can it would get picked up well before it got to inductance testing!
#49
yeah I meant if there was any significant performance increase from running a different rotor it would be questioned and looked at closely.
There are certain physical measurements a rotor has to meet. Diameter and magnet length etc etc. If the one out of the 10.5 fit the measurements for stock then all good but if it was a modified rotor it would be picked up easily from the rotor measurements.
#52
Having done some research accommodation is looking a bit scarce. I did find a place reasonably close that has rooms however. If you're in need, try this mob: http://www.johnsonroadmotel.com.au/
Now I just hope I can get from the airport to the track in time for heat 1 on Saturday! I predict Cheese and I will set a TQ run from the airport to Redbank Plains!
Cheers,
Scotty
Cheers,
Scotty
#53
Hey all.
For info AARCMCC have updated their website with the newer ESC list that was used at the Nats. It's the January 2012 list. Doesn't have the latest Tekin and Orion approvals that are on the latest ROAR list. We are hopefull AARCMCC may have a new list out in time for the titles that reflect the latest ROAR list but can't count on it.
SO as it stands at the moment the official Stock ESC list will be the Jan 2012 list on the AARCMCC website.
#54
#59
bump for a great event
less then a month out should this event be a sticky by now up the top
such a shame so many people leave things to the last minute to enter
come on guys help out the hosting club get those entry forms filled out and sent in
great track and should be awesome racing on the new design and surface
