HS-6965HB issue. Strange. Need advice.
Hey guys.
Love Hitec Servos. Been using them pretty much exclusively for a couple years. Only had 2 issues to date, with this most recent one leaving be scratching my head.
At an onroad carpet race today my xray's 6965 servo somehow went off center and lost 75% of right turn movement. I was making good laps and after going through a quick chicane into a right handed switchback leading into the straight my car never centered up on the back straight and turned right into the wall.
When I picked up the car it appeared as if the servo horn had stripped, thus being off center and leaving my wheel turned hard right. However, I use an aluminum servo horn so that wasn't the case.
After removing the servo from the car I checked the movements and it turns just fine to the left but will only turn about 25% to the right. All of my radio settings are centered. I have no clue what caused this. The servo has been used for about 15 weekends, and prior to this had worked flawlessly.
Can anyone help?
Can anyone help?
Originally posted by Tres
What car is it in?
What car is it in?
Thanks man.
hi, i had a problem with mine brand new, i aligned it straight and went off, a couple of mins later it started curving left, i aligned it straight again from my transmitter sub-trim. it went sraight for a min or so and started curving right, again i aligned it straight from my transmitter and the same thing happened over and over. can anyone help?
