hs-5925mg servo problem
here is my problem, i ran all day last saturday fine.
today, i decide to change the voltage regulator from the novak 5 amp bec to the muchmore 5 amp bec regulator-no reason, just trying something different.
both regulators work perfect, input is 7.4 volts, with output of 6v on novak, and 6.5v on the muchmore- this was measured by my fluke meter.
i plug everything on and the steering servo works perfect, but i try out the throttle servo(hs-5925mg) and it works ok, then i lower the epa on the transmitter, all of a sudden, i pull the throttle, and it goes just a little bit, then i brake, it goes little bit, then even less, and then, it doesnt turn at all.
for no reason it burned up, i opened it up and i smell the burnt diode smell.
i checked the output of the regulator, it was still 6.5v so it was obvious the .5 volt killed the servo.
why??
