Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-29-2009, 03:39 PM   #1
Cory Kerber's Avatar
Default 5955 Motor Doesn't Stop
I recently greased my 5955 with White Lithium grease. Then today i read on Hitec's website that this type of grease produces a gas the may put a film on the motor brushes. So now my servo motor will not stop running. The only thing i can get it to do is run in the opposite direction by turning the wheel on my radio, but once i release the wheel, the motor goes back to the other direction. When i do this with the gears/case installed, the servo will max out and stop spinning unless i turn the wheel. Would the film on the brushes cause the servo to do this? And if so what should i do to fix it.
Xray XB8-Caster Grenade-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 07-29-2009, 05:24 PM   #2
Nevermind, i just lost the white plastic piece that works the centering mechanism. Now i need to find one.
*TEAM TERRIBLES*
Old 08-03-2009, 07:55 AM   #3
Billy T.'s Avatar
What plastic piece are you referring to?
Hitec RCD, INC.-----Multiplex USA-----Hitec RCD, INC-----Multiplex USA-----Hitec RCD, IN
WWW.HITECRCD.COM
WWW.MULTIPLEXUSA.COM
Billy T. is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
