Hitec 5945 specs?
Spec
Detailed Specifications
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.16sec/60° at no load
Operating Speed (6.0V): 0.13sec/60° at no load
Stall Torque (4.8V): 152.75 oz/in. (11kg.cm)
Stall Torque (6.0V): 180.53 oz/in. (13kg.cm)
Operating Angle: 40 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 3mA/idle and 180mA no load operating
Current Drain (6.0V): 3mA/idle and 230mA no load operating
Dead Band Width: 1usec
Motor Type: Coreless
Potentiometer Drive: Indirect Drive
Bearing Type: Dual Ball Bearing
Gear Type: 3 Metal Gears, 1 Resin Gear
Connector Wire Length: 8.66" (220mm)
Dimensions: 1.55" x 0.78"x 1.48" (39.4 x 20 x 37.8mm)
Weight: 1.97oz (56g)
360 Modifiable: Yes
