  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing HFP-20
1 Posts Since Nov 2008
Old 11-09-2008, 06:34 PM Questions?? HFP-20 View Big Joe's Profile Reply With Quote
Post #1
Hey,
I am Joe and I am new to the forum, had a question or two regarding the HFP-20. I purchased the the programmer primarily to set the deadband on a couple of HS 5745MG's I bought to run the steering in my 5th scale car. That was self explanatory and it took longer to read the directions than to set the deadband. So, after that was done I was trying out a couple of the other options available. I noticed that I couldn't get a value on the overload tab. Is that because my servos are not G2? I also noticed that the speed was set to 1...out of a possible 64. Am I misunderstanding the values and assuming that the higher value is faster or is that the delay for the cycle of the travel. Would appreciate your input and thank you in advance for the help.
Company Representative
Poway, Ca
370 Posts Since Nov 2004
Old 11-10-2008, 07:24 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #2
Only the new 7xxx series servos will have the overload protection function which is why you can't set anything with your servo.
The number to teh left of the : is what the servo is currently set for in terms of speed. A higher number is faster. The number to teh right of the : is what you want to set the servo to so when you have it selected to teh number you want, press the "M" button to store that setting and you will see the number to the left of the: change to what you had selected to the right of the :.
Forum Jump:
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
