Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Last evening my servo just stopped working. I tried a bench test external to the car and found that if I fully rotate one direction and then turn on power, it would recenter but would not see any control from the TX. If I go full travel in the opposite direction, I get no response when power is applied.
No sounds or anything
I opened the servo and found 5 wires coming from the mini PCA. Orange & Brown going to one motor while Red Yellow and Green to another potentiometer looking device.
Any thoughts how I can benchtest this externally? Apply 5V between what leads to see if the motors work.
