  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing HS-6985HB Use Question
holechit's Avatar
TEAM FORD - Redding, CA
536 Posts Since Feb 2007
Trader Rating: 35 (100%+)
Old 08-11-2008, 07:47 PM Default HS-6985HB Use Question View holechit's Profile Reply With Quote
Post #1
Hello,
I've got a HS-6985HB servo I used in an old airplane. I was wondering how it would hold up in an 1/8 scale off road nitro buggy? The torque and speed would be good as far as a throttle servo but will the Karbonite gears hold up? If not, can the gears be replaced with say those of the 5955TG?
Thanks in advance for your time, Tim
Sponsors: Visa, Mastercard & American Express
Company Representative
Poway, Ca
370 Posts Since Nov 2004
Old 08-12-2008, 07:06 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #2
1/8 scale is very brutal on servos. The Karbonite gears in this servo probably wont last very long under normal 1/8 scale bashing around and unfortantually there is not another gear set that will fit in there. If you want something that has a chance of surviving in there you need to took at the higher end metal and titanium geared servos. The best combo we have found is the 5955/ 7955TG for steering and 965/985MG for throttle.
holechit's Avatar
Old 08-12-2008, 08:12 PM Default View holechit's Profile Reply With Quote
Post #3
I appreciate your quick response. I actually have a few 5955 servos so I will continue to use them and save the 6985 for aviation.
Thanks for your time, Tim
Forum Jump:
HS-6985HB problem.. domjames Ask Hitec 2 11-24-2004 06:36 AM
noisy servos >>> hs-6985HB foampervert Ask Hitec 2 08-13-2004 02:46 PM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 08:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 11:46 AM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 09:33 AM
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
