  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing reversing the servo?
whitrzac's Avatar
baraboo wisconsin
1,059 Posts Since May 2008
Trader Rating: 22 (100%+)
User is Online
Old 07-28-2008, 11:17 AM Default reversing the servo? View whitrzac's Profile Reply With Quote
Post #1
I have a slight problem, I bought this fails safe and it worked great with my futaba servos, but I recently got a HS645 servo for the throttle, and the fail safe turns the servo in the wrong direction, going to full throttle, now I need to set it every time I drive, wich sometimes doesn't happen and bad things happen is there any way that I can reverse the prality of the servo motor, without serios problems? I know that it will void the warrenty but that doesn't realy matter.
Company Representative
Poway, Ca
370 Posts Since Nov 2004
Old 07-28-2008, 02:24 PM Default View BRENDAN LUGO's Profile Reply With Quote
Post #2
If you want to reverse the direction that that servo travels you have to go in and swap the outside wires on the pot as well as the wires on the motor.
whitrzac's Avatar
baraboo wisconsin
User is Online
Old 07-28-2008, 04:58 PM Default View whitrzac's Profile Reply With Quote
Post #3
ok, would I need to swich the wires on the pot if the radio has servo reverseing?
what about taking the servo lead and swiching those wires insted?
Poway, Ca
Old 07-29-2008, 07:12 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #4
Yes you would, otherwise all you will do is reverse which way your throttle brake works on the trigger.
All you will do is fry the servo doing this.
whitrzac's Avatar
baraboo wisconsin
User is Online
Old 07-29-2008, 01:42 PM Default View whitrzac's Profile Reply With Quote
Post #5
thanks I got it working now
Forum Jump:
Novak Spy reversing ESC NEW tc3drivers R/C Items: For Sale/Trade 0 09-04-2008 08:07 PM
Small reversing ESC dway100 R/C Items: Wanted to Buy 2 01-21-2007 11:27 PM
WTB:Inexepensive Reversing Esc TexRacer R/C Items: Wanted to Buy 3 07-03-2005 08:14 AM
TC3 reversing wierd Shiz Electric On-Road 8 02-05-2005 08:01 AM
EZX-R Pro not reversing proudcanadian Ask Hitec 2 09-05-2003 09:23 PM
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
