  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing HS 645MG servo question
3 Posts Since Jul 2008
Old 07-28-2008, 12:33 AM Default HS 645MG servo question View dirk41's Profile Reply With Quote
Post #1
Hi guys,
I have an application that requires the use of HS 645MG servo motor. I'm connecting my microcontroller pin(generating PWM signal) directly to the signal pin of the servo. I would like to ask if connecting them directly is a correct thing to do? or are there other circuit like feedback sensor, etc that needs to interface both the micro and the servo?
Thanks,
Company Representative
Poway, Ca
370 Posts Since Nov 2004
Old 07-28-2008, 02:19 PM Default View BRENDAN LUGO's Profile Reply With Quote
Post #2
As long as you are sending the proper signal it should work fine.
Old 07-28-2008, 06:00 PM Default HS 645MG servo question View dirk41's Profile Reply With Quote
Post #3
Hi Brendan,
Thanks for the info. My application includes one device(T1) that tracks the other device (moving object). What im thinking is to program the microcontroller to save the angles of the moving object (with respect to T1) which to be used in order to manipulate the servo motor.
It is the microcontroller that feeds a PWM signal to the servo motor
Thanks,
Forum Jump:
HS-645MG question Baedarlboo Ask Hitec 2 03-29-2008 11:17 PM
hitec 645mg servo rcheadcrazy R/C Items: Wanted to Buy 2 11-01-2007 05:14 PM
HiTEC 645mg servo and 945mg servo for sale SCUBA STEVE R/C Items: For Sale/Trade 10 02-09-2006 07:48 AM
HITEC HS-625MG SERVO AND HS-645MG SERVO RC-PARTS R/C Items: For Sale/Trade 0 10-10-2005 08:41 PM
servo savers 645MG corvettecrazy Ask Hitec 9 08-22-2003 04:06 AM
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
