Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Well I put the 645 in and the steering is not any better. Still have the same turning issues. It takes nearly a two car driveway width to turn around?????????? Without the servo linkage hooked up the steering has not bind in it at all. Hooked up the servo linkage and still the same issue. Turning the wheel to full left or right, the servo will only turn the wheels a few degrees. The servo still has at least 50% more travel left. But it will not go full lock to lock??
