There are only a few things that cause a servo to burn out. Barring a defect in a component, the only things that will fry it are water or other liquids getting on to the electronics and corroding them, stalling the servo, or applying too much voltage to the servo. Digitals are very sensitive to setup and they need careful attention. An extended load applied to the servo will cause the circuit to heat up and eventually let the magic smoke out of it. This is the #1 failure mode we see with digitals and certain setups like rock crawlers are prone to it. The other thing to watch out for is to not forget to turn off the power to the car. If the power to the car is still on but your transmitter is off, the receiver can pick up stray signals in the air and drive the servos hard over causing them to stall, over heat and burn out. You may just want to just triple check your setup to make sure it is copasetic.
