  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing Rant about Hitec HS-5645MG
47 Posts Since Apr 2008
Old 05-17-2008, 01:55 AM Thumbs down Rant about Hitec HS-5645MG View drakuli's Profile Reply With Quote
Post #1
Bought it on Wednesday together with HS-5625MG for my Hyper 8.
The 5625 is okay but the 5645 was broken last night when I test it.
I simply put it on my buggy and the horn wouldn't center and it could only turn to one way. I brought it to the shop just now and they said the gear is broken. I didn't even use it but they accused me of "abusing it". What a lame service and quality.
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
WWW.TNT-FX.COM
3,018 Posts Since Oct 2001
Old 05-17-2008, 05:16 AM Default View Tres's Profile Reply With Quote
Post #2
Send it in to service and they should get you set up.
6xx series servos and 8th scale are not the best choice.
8th scale is VERY hard on servos in general.
Tre's
Custom Graphics - Race Plates/Wraps & Pit Products
www.tnt-fx.com
Poway, Ca
370 Posts Since Nov 2004
Old 05-19-2008, 08:28 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #3
So you have a new servo never used but somehow the gear is broken? That just does not add up. Obviously the servo was used and either setup incorrectly or the vehicle hit something. Metal gears just don't strip on their own. In any event you do have a 2 year warranty and on this servo (MP or MK gear train servos) we do warranty the gears against breaking. What you need to do is send it to service with a copy of your receipt for warranty coverage.
And as Tres pointed out the 56xx series servo is on the bottom end of what would be recomended for an 1/8 scale vehicle. 1/8th scale is very brutal on servos so a high quality servo like our titanium geared servos from the get go will keep you running much longer before having to rebuild/replace your servos.
And you are using one of the horns that came with the servo or one made for a Hitec servo correct? Every servo manufacturer has a different spline count so they are not interchangable.
Old 05-20-2008, 12:44 AM Default Sorry, I take my rant back View drakuli's Profile Reply With Quote
Post #4
Sorry, I think just now I know what caused it. It's probably due to wrong screw. I mistakenly put a similar screw set to attach the horn, however it is longer than the original one (same color, same diameter, only longer). So probably since it was penetrating too deep into the servo, it may had touched some fragile things inside the servo.
So, I take my rant back. Once again sorry.
Poway, Ca
Old 05-20-2008, 07:58 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #5
If the screw is too long it can hit the top of the potentiometer, pushing the shaft down into the ceramic disk inside and bend the metal housing causing strange behavior in the servo.
Old 05-20-2008, 08:15 AM Default View drakuli's Profile Reply With Quote
Post #6
Can it be fixed?
Poway, Ca
Old 05-20-2008, 08:35 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #7
Yes, we can replace the potentiometer in the servo.
Old 05-20-2008, 09:30 AM Default View drakuli's Profile Reply With Quote
Post #8
Ok, will send it for repair.
And just a suggestion, maybe the R&D can find a way to prevent same thing happens again in the future by putting a kind of barrier so the screw tip will not touch anything inside.
Forum Jump:
Hitec 5645MG screw backing out ? inconceivable Radio and Electronics 4 09-01-2008 07:45 PM
Hitec HS 5645MG Servo reynolds716 R/C Items: For Sale/Trade 23 11-12-2007 04:39 AM
Hitec HS 5645MG Servo reynolds716 R/C Items: For Sale/Trade 2 10-27-2007 10:43 AM
WTB: Hitec Digital Servo's, MT, prefer Hitec HS-5645MG Izze-Racing R/C Items: Wanted to Buy 2 04-21-2006 03:17 AM
Hitec 5645MG Crapped out mike_Webb Ask Hitec 15 06-09-2002 09:29 PM
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
