Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
I'm working on a project where I have to control air in a cylinder so I am using a needle valve.
The needle valve takes 10 turns to go from full open to full close. I need to be able to turn the valve anywhere between open and close.
I was thinking about using a servo since I would know how much it has turned, but what servo do I need to use? Is there any way to make a servo do a single full rotation and stop, and then repeat this process over and over?
I will be using a microcontroller to create the pulses.
I'm new to servos so any help would be appreciated.
There is nothing standard that will fit your bill so if you want to use a servo for it you will have to modify one. Check out www.lynxmotion.com for how to modify servos for continous rotation.
