  Register
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Welcome to the R/C Tech forums! If this is your first visit, you must create an account before you'll be able to post messages. If you are already a registered user, please log in using the form below.
Go Back   R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Log in Above!
Viewing Problem with 5925 digital servo
2 Posts Since Mar 2008
Old 03-19-2008, 02:10 PM Default Problem with 5925 digital servo View Alex_Dek's Profile Reply With Quote
Post #1
I have a 5925 digital servo that I use for steering on my 1/10 car, an Asso B4. I own this servo from about an year, and it has always worked fine. Suddenly it started to pause when returning to center. I can turn one way, but when I go to turn it to center or the opposite direction - it sort of pauses then turns the intended direction. If I turn slowly in both diretions it works, but if I turn faster, it starts to pause. One or more seconds pause! I have read another one has had the same problem with the same servo in the past. I own an Hitec 4 Flash Pro tx/rx with LRP 7.1 ESC and a Sanwa (Airtronics) M8 tx/rx with Mamba Maxx ESC. Same problem. I also checked the servo with the Hitec HFP-10 Digital Servo Programmer and it works FINE. unbelievable
Any help ?? It needs TLC? I presently live in Italy, can I find a service here?
Thanks in advance
Alex
Company Representative
Poway, Ca
370 Posts Since Nov 2004
Old 03-20-2008, 08:17 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #2
Has the servo always been used with this equipment or is this a new setup and a new problem? Whats teh BEC amperage rating on that LRP ESC? Is this problem occuring with the Flash or the M8 or both radios?
Your service center in Italy is:
ITALY
SAFALERO
MR. ROMUALDO
GAROFALI VIA DELL’ARTIGIANO 29,40065
PIANORO, BOLOGNA, ITALY
39-51-6516132
39-51-6516197
rg@safalero.it
Old 03-20-2008, 04:36 PM Default View Alex_Dek's Profile Reply With Quote
Post #3
Hi Brendan,
thank you for your fast reply. Yes, the servo has always been used with this setup and it's a new problem that occurs with both radios. The ESC is a LRP 7.1 digital, you can find the spec here
It's a good ESC as Mamba. I don't understand why the servo works fine with the Hitec HFP-10 Digital Servo Programmer. Any suggestion?
Alex
Poway, Ca
Old 03-21-2008, 08:28 AM Default View BRENDAN LUGO's Profile Reply With Quote
Post #4
Originally it sounded like maybe a motor issue but if it works properly when connected to teh programmer then it sounds like a voltage/amperage issue (not getting enough). If the servo acts up only when ther eis a load applied to it then I would say you are exceding the amperage limit of the ESC's BEC current.
Jacksonville, FL.
317 Posts Since Jun 2006
Old 03-24-2008, 03:11 AM Default HS-5965MG View Mik G's Profile Reply With Quote
Post #5
I have the same problem with my HS-5965MG . I'm using Novak GTB and I can not get it to center.(no load) I changed radios and everthing. My 645 worked fine. Do I need to send it back?????
Tres's Avatar
R/C Tech Charter Subscriber
WWW.TNT-FX.COM
3,018 Posts Since Oct 2001
Old 03-24-2008, 04:34 AM Default View Tres's Profile Reply With Quote
Post #6
Mike G, I would send it to make sure all is well.
Tre's
Custom Graphics - Race Plates/Wraps & Pit Products
www.tnt-fx.com
Forum Jump:
WTB-Digital Servo(925 or 5925),NiMh AA's Stevietd14 R/C Items: Wanted to Buy 2 07-29-2005 09:19 AM
Hitech 5925 digital servo nitro kid R/C Items: For Sale/Trade 17 05-26-2005 03:40 PM
Hitech 5925 digital servo dan-o R/C Items: For Sale/Trade 3 05-19-2005 12:46 PM
HITEC 5925 Digital Servo SpeedChair R/C Items: For Sale/Trade 8 06-30-2004 01:20 PM
Hitec 5925 digital servo xxxtracer R/C Items: For Sale/Trade 0 07-03-2003 05:42 AM
Powered By: vBulletin v3.6.7
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
