Go Back   R/C Tech Forums > North American Regional Forums > Alabama Racing
Old 05-19-2016, 05:12 PM   #1
TeamGPT88's Avatar
Default OSRC ONROAD Carpet Racing Gautier MS
OSRC carpet race schedule for the rest of 2016:
June 11
July 9, 10. Trophy race
August. 13
September open
October 8
November 12
December open
Location is:
Duo Dance Event Center
3100 Ladnier Rd
Gautier MS 39553
TeamGPT88 is offline   Reply With Quote
Old 09-30-2016, 07:15 AM   #2
TeamGPT88's Avatar
Trophy Race Oct 8th
Old 09-30-2016, 07:22 AM   #3
TeamGPT88's Avatar
Mississippi Gulf Coast R/C Raceway on facebook
Old 09-30-2016, 07:26 AM   #4
TeamGPT88's Avatar
JAMIE BELL 228-872-3918
Old 12-25-2016, 05:49 AM   #5
TeamGPT88's Avatar
The starting schedule for 2017 will be
January 21
February 25
March 25 Trophy / Double Points
April 8
May 13
June 10
That is the next races. I was thinking about doing a points series also.
Old 01-11-2017, 08:55 PM   #6
TeamGPT88's Avatar
Touring
17.5 Touring Sedan
o 17.5 Roar legal brushless motor (D3.5 is also legal)
o Blinky ESC
o Rubber tires 24mm or 26mm
o 2 cell 7.4 battery
o GBS body rules 190mm
o Rear wing no higher than roof line or wider than car
o 4mm ride height
o 1380 grams weight
o 5 min heats and mains
USGT Touring Sedan
o 21.5 Roar legal brushless motor
o Blinky ESC
o Ride / Gravity Spec tire or HPI X Patterns
o 24mm or 26mm spoke rims. NO dish wheels
o USGT Body 190 or 200mm body. NO Touring, WGT, Vans, SUV, etc.
o 5mm ride height
o 1380 grams (4wd) 1200 grams (2wd) weight
o 6 min heats and 8 min mains
VTA Sedan
o Novak 25.5 brushless motor, Team Scream 25.5, Motiv 25.5, any Roar approved 25.5
o Blinky ESC
o 2 cell 7.4 5000 MAH limit battery
o VTA wheels and tires 26mm fronts #4793 and 31mm rears #4797 stock inserts. No tread rule. No sanding of tires.
o Vintage Body (driver figure is optional)
o 5mm ride height
o 1450 grams weight
o 5 min heats (gang starts) and 8 min REVERSE mains
F1
o 25.5 2 cell 7.4 battery
o Blinky ESC
o Open F1 rubber tires
o Molded wings
o 3mm ride height
o 190mm width
o 1050 grams weight
o Hard plastic wing (No Lexan)
12th Scale
o 13.5 Roar legal brushless motors (D3.5 legal)
o 1 cell 3.7 battery
o Blinky ESC
o Foam tires
o GTP style body
o 3mm ride height
o 730 grams weight
o 8 min heats and main
WGT
o Blinky ESC
o WGT Spec tires
o Standard WGT body
o 104mm body height
o 4mm ride height
o 930 grams weight
Oval
13.5 Pro Oval
o 1/10 Pan oval car
o 13.5 Brushless motor
o Open ESC
o Open foam tires
o 200mm Nascar oval body. Rear wing allowed
o 4mm ride height, 4 roof height
o 36 oz, 1020.583 grams, 2.25 pounds weight
17.5 Truck Oval
o 1/10 pan oval car
o 17.5 tour brushless motor (D3.5 legal)
o Blinky ESC
o Spec WGT tires
o 200mm truck body, 2 rear spoiler. NO side dams. Back of body left in.
o 4mm ride height, 4 ⅜ roof height
21.5 Sportsman Oval
o 1/10 pan oval car
o 21.5 brushless motor
o Blinky ESC
o Open foam tires
o 200mm Nascar oval body: 1.5 spoiler, back of body left in, NO rear wing. 4 roof height
o 200mm truck body: 2 spoiler, back of body left in. 4 ⅜ roof height
o 4mm ride height
SK Modified
o 1/10 SK pan oval car
o 17.5 brushless motor
o Blinky ESC
o Open tires
o SK body
o 3mm ride height
o 33 oz, 935.534 grams, 2.062 pounds weight
o SK-KAR National Rules
Legend
o RJ speed, Bolink legend car: Bearings, turnbuckles, and servo mounts allowed
o 20t Dynamite brushed motor
o 48 pitch 81 spur: 21 or 22 pinion gear
o Brushed ESC
o Spec WGT tires
o 1800 nicad battery
o Legend body
o 4mm ride height
o 34 oz weight
Stadium Truck Oval
o 2wd 1/10 stadium truck
o 10.5 brushless motor
o 2 cell 7.4 lipo
o Open ESC
o Slick stadium truck tires. Panthers and Primes
Mudd Boss
o Traxxas 2wd slash or raptor: Traxxas Low CG chassis is allowed
o Original MFG parts only. NO aftermarket hop-ups, no aluminum parts
o Front bumper must be removed, side bumpers can be removed if desired
o Traxxas front optional (tra2735) can be used (angled down)
o NO alterations to the chassis (such as holes, or removal of material)
o Front body post brace MUST be removed
o 13.5 Roar legal brushless motor (D3.5 legal)
o Spec ESC (NO TIMING OPTION POSSIBLE)
o Traxxas 2075 and Savox SC-0252
o 2 cell 7.4 5200mah 50c battery
o 76/83/86/90 spurs only, any pinion
o NO modification can be made to the transfer case
o You are allowed to move the wheel spacers with any combination or both
o Tranny Functionality Rule (motor cannot spin while turning one rear wheel)
o Original shock and springs only (NO LCG kit springs or aftermarket springs)
o Front springs may be cut to shorten them. Shock travel may be shortened with internal shim fuel tubing
o Original pistons from kit only, NO modifications can be made to them
o Mudd Boss Jaco foam tires
Pancar Busch Series
o Any 1/10 pancar
o Any NASCAR body
o Purple or Yellow WGT spec tires
o RJ speed red front springs
o 81 tooth 48 pitch spur gear
o 20t - 26t pinion
o Duratrax 1800nicd battery
o Photon2 motor
o Any springs in center and side shocks
o Back of the body can be cut out
o Wings are optional
o 4mm ride height
o 38 oz weight
o Tech: Checking batteries and motors to see if they have been opened
Blinky Buster
o Anything over a 2.1 will be illegal and considered boosted
LIPO Rule
o Touring
 1S max voltage is 4.20
 2S max voltage is 8.40
 90 degree max temp rule to race
o Oval
 1S max voltage is 4.22 if over you must bleed to 4.20 to race
 Mudd Boss 8.44 max bleed to 8.40 if over
Old 03-22-2017, 04:44 PM   #7
TeamGPT88's Avatar
Trophy race this Saturday.
Old 04-02-2017, 08:30 AM   #8
TeamGPT88's Avatar
Club race this Saturday, April 8th.
Old 06-30-2017, 09:38 PM   #9
TeamGPT88's Avatar
Default Trophy Race July 8th and 9th.
Old 07-16-2017, 07:55 AM   #10
TeamGPT88's Avatar
The next club race dates:
August 12
September 9
Old 10-08-2017, 04:37 PM   #11
TeamGPT88's Avatar
Default Club Race
Next CLUB POINTS RACE is on October 14th.
