Go Back   R/C Tech Forums > North American Regional Forums > Alabama Racing
Old 09-17-2012, 10:17 AM   #46
Csaari77's Avatar
Trader Rating: 34 (100%+)
Excuses are the stepping stones to failure Nick.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 09-17-2012, 04:12 PM   #47
bhambrent's Avatar
Originally Posted by Spider004 View Post
101 in Mini!!!!!LOL
Just for you this year, 4th Class is FREE!
The entry fees went down some this year and the $10 will go straight to the pot.
Pot I do not want any tweed man! I'll take a beer.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 09-17-2012, 07:10 PM   #48
bhambrent's Avatar
Originally Posted by ChrisR40 View Post
Does anybody have an extra 1s battery or the oval guys have one that I could get. Trying to keep cost down until I can get some more funds.
I did but put it in on the trade I made.
Sorry, but I still have a 13.5 motor for you.
Old 09-17-2012, 07:21 PM   #49
bhambrent's Avatar
Old 09-17-2012, 08:29 PM   #50
Csaari77's Avatar
Does anybody have an extra 1s battery or the oval guys have one that I could get. Trying to keep cost down until I can get some more funds. Planning on running the Carpet Knife and see what car does best and my go that route. Now what body to run, hmmm.
Check this site out. Nice battery for a great price.
http://www.discountlipos.com/searchresults.asp?cat=1847
Old 09-17-2012, 08:30 PM   #51
bhambrent's Avatar
Originally Posted by RedBullFiXX View Post
Ok Racers here it is.
A compiled list of information, and links to help guide you on your quest to build and race 12th scale.
If you live in So-Cal....
At the moment the only track with a regular showing of 12th scale racers is TQ Racing in Chino Hills
http://www.tqrcracing.com/
Camarillo RoadRunners on occasion have a group also
http://www.roadrunnersrc.com/
If your willing to travel up the Golden State a bit north, NorCal Hobbies have a good group of 12th scale racers with a massive, smooth outdoor track.
http://www.norcal-hobbies.com/
Setup tips
carsrcracing.co.uk
Mark Payne's 1/12th Scale RC Notes
R/C Car Handling website; Everything you need to know about vehicle dynamics
CARSrcracing.co.uk; Starting 12th scale with L4 based cars
CARSrcracing.co.uk; More 12th scale articles
CompetitionX; RC Tuning Guide
12th Scale.info
Pod Droop vs Chassis Sag - Bruce Carbone -
Gear Rollout Chart
Setup Sheet Database
Setup & Build Tips by Andy Griffiths
Team Associated RC12R5 - Dennis King - Fast rules to setup your car
How to build a Ball DIfferential, by Dave Irrgang (IRS)
Petit RC: Technique Guide to all things RC
How To Solder Correctly
Quick Guide and 12th Scale Setup tips by Richard Chang
Xenon Rollout Sheet
12th Scale Forums
12th Scale Thread
Classic 12th scale
How to mount a 12th scale body
LRP-X 12 series timing info
Foam Tire Shore Ratings
Black - 40 shore: This is a low natural rubber compound. Special tire for insane traction carpet tracks. Does not get gummy like Purple. If you don't have insane traction you car will likely push with these.
Purple - 40 shore: This is a natural rubber compound. Popular front stock tire, carries good corner speed because it's firm. The foam this compound is made from gets more gummy late in a race. The more you run this compound the gummier and stickier it gets. A little more forgiving than some of the other fronts.
Lilac - 37 shore: This is a natural rubber compound. Great front tire for stock carpet or if dbl. pink is too much steering.
Double Pink - 35 shore: This is a natural rubber compound. This is the standard front tire for carpet in all classes. Its is used front and rear for 19T and Mod carpet and front and rear in all classes on asphalt.
Grey - 35 shore: This is a low natural rubber compound. It is just as hard as dbl. pink but it has FAR LESS traction. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed. This is the old standard rear carpet tire, most stock carpet racers use the softer yellow compound now for more forward grip.
Magenta - 32 shore: This is a natural rubber compound. Its softer than dbl pink so if you need more steering than dbl. pink use these up front. If you need more rear traction than dbl. pink use these in the rear.
Pink - 30 shore: Pink - 30 shore: This is a natural rubber compound. This tire is used in mod 1/12th on carpet and asphalt if the traction is low. If the traction is high it will lock in the rear of the car and make it push.
Orange - 30/35 shore: This is a rear tire with 2/3 yellow compound on the inside, 1/3 grey compound on the outside. This tire will free up the back of the car, also giving similar grip to yellow with added durability of a grey compound. Also known as Grey-Low
Yellow - 30 shore: This is a low natural rubber compound. It is the standard rear tire for Stock racing. It is used to free up the rear of stock powered carpet cars for more efficiency and corner speed.
White - 25 shore: This is a low natural rubber compound. It was the standard rear tire for 1/10th on road carpet racing. Its a little softer than yellow.
The main difference in the "Yellow" family and the "Pink" family of tires, is that the Yellow has a low rubber content and does not heat up as much and get gummy like the Pinks do.
If the track is greasy the Yellows are better, but the higher rubber content of the Pink family will generally have the most grip as long as they stay gum free.
Wheel spec chart (credit to kimihiko-yano.net)
And here is a an easy to use Tyre Truer-Adpater from the good folks at CRC
Ultimate Tire Grinding Tool from C.Andy's RC Prototypes in Germany
Team Tamale Tire Truing Adapter
Ok, now this is the fun part, where you get to pick out your favorite new kit
Colors optional
Alien Racing
Team Associated RC12R5.2
Team AE Forum
Volker Worlds Setup Sheet
Howhart Worlds Setup Sheet
________________________________________________
BMI Racing Copperhead 12
BMI Forum
CEFX Griffin 12 2011
CEFX Forum
CORALLY 12SL
Corally Forum
CRC Gen-Xti
CRC Xti Forum
Kyosho Plazma 1/12th
Kyosho Forum
LAJE Corner Thief 2012
On-Point Racing.com
On-Point OP12C
On-Point Racing Forum
Upgrade parts list for 120L & 12r5
SpeedMerchant Rev7
SpeedMerchant Forum
Peter Robinson Rev7 setups 2011 iic
Serpent S120LT
Serpent Forum
Tamiya RM-01
Tamiya RM-01 Forum
Setup Info
T.O.P Rebel 12
Top Racing USA
Top Racing Forum
V-Dezign CR-V
V-Dezign Forum
XRAY XII
XRAY Forum
Yokomo R12
Yokomo Forum
Popular Electronics, Servos, Speed Controls, Accessories & Information for 1s Racing
TQ Racing Wire
Tekin RS/RS PRO on 1s Lipo Q&A
Tekin Team Driver Setups
Boost=electronic timing advance, this is the most efficient way to drive a brushless motor, the timing is applied incrementally to keep peak performance from 0 rpm to max rev limit, the issue here is that a 17.5 motor for instance, is now as quick as a 13.5 motor for 1s, and more like a mild mod motor with 2s.
Timing= a mechanical adjustment to the endbell of a motor like in the brushed motors of days gone by. This method of timing advance will also increase performance to a point, but in doing so the motor will produce more heat, and reduce durability over time.
Blinky mode refers to no electronic timing advance.
Open esc = boosted, or modified.
HobbyWing
Xerun 120A-1s
LRP
SXX Comp VII
SXX Stock Spec VII
SXX TC Spec VII
TEKIN
RS
RS-PRO
TQ Cells - 1s Lipo Booster
Novak 1S Lipo Booster
Futaba
Digital Brushless
BLS 651
Digital
S9650
Analog
S9602
JR
Z3650
KO Propo
PDS-951
Old 09-18-2012, 07:38 AM   #52
MCSEDanny's Avatar
Nicely done Brent.
Here is a car with all the right stuff if someone just works him for a better price (1/12 have no resale value right now)
Speed Merchant rev7 sport
Team Turtle Trax / Loganville RC Raceway
Mugen MBX6TR / Bonito
Kyosho MP9 TKI3 / Plus 4
Kyosho MP9 TKI3 / Electric / WTF
AE B44.3 / ORCA VXX / D4 7.5
MCSEDanny is offline   Reply With Quote
Old 09-18-2012, 07:40 AM   #53
MCSEDanny's Avatar
Also if going with the LRP SC's for 1/12 1S make sure it's V2 or you will need a receiver pack or booster.
Old 09-18-2012, 08:50 AM   #54
bhambrent's Avatar
Originally Posted by MCSEDanny View Post
Nicely done Brent.
I found that post in the 1/12 forum,a little cut and paste.
Old 09-18-2012, 02:39 PM   #55
RCTWENTY8's Avatar
TY for all the info!
Full circle we go!
RCTWENTY8 is offline   Reply With Quote
Old 09-19-2012, 10:56 AM   #56
To much informmmaation, brain oooovvveerrr lllooaadd.
The serpent looks nice. Well first things first, got to get my old CRC going and then I will look into a new car. Have to get something for myself for Christmas.
ChrisR40 is offline   Reply With Quote
Old 09-19-2012, 11:26 AM   #57
bhambrent's Avatar
your welcome.
Just need to find the right tires combo and gearing, and we should be good..
Old 09-20-2012, 07:17 AM   #58
Csaari77's Avatar
My car is slowly coming together. Only thing I need is for the chassis to get released. I've got a ESC, battery, and body on the way. I'm waiting for tires until the 1/12 run at the dual. Hopefully that will give us a good place to start.
Where's Budman? I need some HP!
Old 09-20-2012, 05:22 PM   #59
bhambrent's Avatar
I will talk to the Nashville guys that are going to iic and see if they can one for you.
On the tires I'm going double pink front and rear to start.
Budman is working on the d3.5 and I'm going to try too get him too send me as many as he can to sale.13.5 and 17.5..
Old 09-20-2012, 05:30 PM   #60
Csaari77's Avatar
Don't worry about the chassis. I've got that handled. They should be shipping soon and I've got one preordered.
I do want a couple of motors though. 17.5 with a high torque rotor for TC, and a 13.5 for the 1/12. Not sure on that rotor though. See what you can find out this weekend.
